JHM oleksiyko
Maybe there is a misunderstanding here. I wanted to say the I just had to play around with the minimum position on 60°(degrees celsius). Also, there is no problem with the idle now, and with the ICV.
My question would point to these three questions:
So I just have to recalibrate the TPS and the CLT, right? (to remove the KJet ECU completely)
What if I do not enable the lambda adaptation? Will it hurt at all?
I tried to adjust the ful correction on idle, because my car is running rich on idle. The problem is, that the more I lean out the mixture at idle, the leaner it will be under load as well. So it will be good on idle, but lean under load with the same amout.
-Or what if I don't touch the corrections (I use the calibration from the firmware I did not modify it) and enable the adaptation?
Thanks!
