oleksiyko
Okay, thanks! Now I know where should I install the EMUL wire and the ignition coil wire. If I connect these two wires to the terminal what I can see on the picture, will the RMP meter work in the cluster as well? Also, you mentioned something about the fuel pump relay. Should I connect it to this terminal as well?
In my case I fed tacho and fuel pump relay from "emul" wire.
Also, how can I power the ignition coil?
Thanks!
