JHM oleksiyko
Thanks for the explanation! So I just have to recalibrate the TPS and the CLT, right?
Also, I have some more questions about my original problem. I finally managed to have an idle around 750, I just had to play around with the minimum position on 60. What if I do not enable the lambda adaptation? Will it hurt at all? I tried to adjust the ful correction on idle, because my car is running rich on idle. The problem is, that the more I lean out the mixture at idle, the leaner it will be under load as well. So it will be good on idle, but lean under load with the same amout. Or what if I don't touch the corrections (I use the calibration from the firmware I did not modify it) and enable the adaptation?
Thanks for your help!
