Performance is much better than with the old KE-Jetronic, the engine runs much smoother now!
I still need to check my Idle switch but this should not concern driving performance.
I have a couple of questions:
1. Can someone please check my Log File? I am not sure but it seems that the AFR is to high (lean) when accelerating.
Which values would you recommend for safe minimum and maximum AFR?
2. Are my Injectors too small? I have 5x Bosch 0 280 158 502 . Would Injectors with an higher CC be better(performance)?
3. Can someone recommend me settings/map for best Performance?
I think AFR should be lower, something like 12.5 maybe I am wrong.
4. Is it possible to use a modern Lambda Sensor (broadband) , something like an Bosch LSU 4.2?
5. Is it Possible to Use 2 maps (I think its possible) and switch between the two maps using a Switch connected to the ECU?
For example: one map for performance and one map for fuel economy.
Thank you very much for your support and help!!!
