[unknown] [unknown]
I need your help ASAP! I installed and setted up everything for the ignition control and tried to start the car. It wants to start, but never succseeds. Before installed it, it was working 100% fine. White smoke coming from the throttle body after trying to start. Here is what I did to install the ignition control:
- Installed 9.0654 FACET and FACET 9.8114,
- Connected it with BERU VESO116,
- Connected hall sensor signal to DH,
- Connected ingniton coil signal to EMUL,
- Disconnected AN,
- Removed whole EZL module,
- Uploaded the V4.1.7 M102 "default config" and M102 igniton config
The only thing I noticed that the Dwell time, ms was set to 8ms, but the coli's Dwell is 5ms, so I tried with it as well. Nothing has helped.
Please help me if you can. I uploaded the logs. The config is the default for V4.1.7
