[unknown]
Thanks for the infos, I'll watch the video on youtube. The hall sensor signal is already inverted, the dwell is 8ms. I'am using the default config for the V4.1.7 firmware, I also tried this config
, but still the same issue. With these configs the engine should have started up, but nothing.
I made a log with the new Beta Invent Commander, here are the logs from it:
. Based on the logs, we have confirmed actual combustion—the engine spiked to 574 RPM (well above the 95–150 RPM starter baseline) with active fuel and spark. However, it immediately stalled and the crankshaft physically stopped turning before the key was even released. I measured the EMUL voltage, it was fluctuating between -0.8V to 5.5V, so it looks completely normal.
Did you have to setup anything in the zero angle correction? Or how is it, that my engine is so misaligned, that it will not even fire up, but someone else's would fire right up without any modification? It is really confusing for me.
What should I try next, to make it run? The only was is to measure it with the strobe?
Thanks!
