vikos The osciloscope indicates that there is no PWM signal,when i'm crank the engine 🙁...coil is not conected. Are you sure my settings is ok?
vikos I've tried so many different things, for example…power the ECU from another power source…set the different settings in commander… put another ECU, nothing. Perhaps you'll see some results.
ivanninn Hi, how are you? I have an M102 2.0 8v with invent and only one tooth on the crankshaft pulley. Could this manual work for this application? Thanks.
VladimirYesin has anyone successfully implemented ignition control by invent on m102 or m103? If yes, please share detailed setup.
JHM oleksiyko This map is based on the numbers in the M102 user manual. m102amg-20260416-174935-v417.imf9kB
oleksiyko VladimirYesin I have made phased injection and ignition control by Invent on M102. What questions do you have?
VladimirYesin oleksiyko I am currently only preparing to install invent jetronic. So basically I need a detailed manual. @JHM announced a month ago that the detailed instructions on ignition control were going to be prepared, but it's still not there
