No matter what I do, I can't get the ignition coil to start.I'm starting to assume that the problem is in the control logic itself, because I only get a spark when the phase icon in the controller lights up.I'll try to explain my setup again.
To determine the TDC of the first cylinder, I installed a camshaft position sensor (it's a smd component small enough to fit behind the ignition distributor cap.)
In my case the camshaft position trigger wheel has ONE tooth and it faces the sensor when the piston of the first cylinder is at dead center.My question is...is there any way to change the logic to my setup?
