sergeyg Firmware 4.1.2 is loaded, but calibrations are not saved. can you tell me what could be the reason?
JHM Check if you're doing all the required steps: https://invent-labs.com/jetronic/docs/en/setup/software.html#firmware-update
sergeyg I do everything via cable. I've been using your product for seven years now. but it is on version 4.1.2 that calibrations are not loaded. auto-save blinks for half a second, but the file doesn't load.
sergeyg OK, everything worked out. slightly behind in development. where can I find instructions for configuring exactly the firmware version 4.1.2. what's on the site is all for version 3.
sergeyg And when will it be? I really liked the idle, but the launch and much more. The calibration of the site requires further development. What should I do?
sergeyg why is the engine temperature displayed correctly in version 3? And in all 4 versions, the readings are 15 degrees lower.
sergeyg I have tried all 4 firmware versions on the same engine. The value 75 is displayed everywhere instead of 90. In version 3.2.18, everything is displayed correctly.???
sergeyg in the garage +23. dtv +20. oj +11. this is in version 4.0.15. switching calibrations does not give anything. the Bosch sensor. Not China. on 3.2.18, all parameters match. The question is, what should I do?
JHM I've never heard of such an issue. Please make a video of what you're doing, and I'll try to help.
sergeyg может и вам пригодится. в мобильном приложении убрал галочку подтяжка и о чудо. темпиратура двигателя поднялась на 12-15 градусов. мелочь а приятно.
