Hi,
Recently I got lambda errors while driving and the idle was around 1000 when this error was present, so I’m thinking on replacing the sensor. I read this page that says if my lambda goes wrong I should use one of these Bosch sensors: 0258986507 or 0258006537. I ordered 0258986507. My question would be: how should I connect the wires with the new lambda sensor with the M102? Especially the ground wire wich does not exists on the original 3 wire lambda sensors.
Thanks!
