the photo is illustrative to describe what I see after each connection. Could the problem be that I can only connect to the unit via Bluetooth? I have never been able to connect via cable. yes, I followed the instructions on the website where you have the individual sections of the ecu listed, you can also set them manually. I had everything filled in and it still wouldn't be saved to the ecu. But even if I didn't fill in everything, it still has to be saved to the ecu, right?
