Okay, changed the pull up resistance and now I'm getting it to show the correct temp at idle, however when I move the throttle position it shows a change in coolant temp, the more the throttle changes the lower the temp will indicate. I'm having a problem getting this throttle position sensor to calibrate, almost every time I restart it after a cold soak I will have to recalibrate it. Is it possible a bad throttle position sensor can throw off engine temp readings since they both share the same low reference from the MAP sensor?
