Hello!
We are back with another update.
We have checked and double-checked the wiring. Everything is good.
If we plug an LED into injector connector #3 and turn the ignition on, the LED lights up immediately and stays on. If we repeat the same test with the injector connector #4, the LED stays off until the starter is activated. Then it flashes. There are other symptoms that I won't go into which tell us that injector #3 was always on.
We have now opened up the ECU. On the board, we can see 7 mosfets, all in a row. 6 are identical with one being different.
Our theory is that Q3 is the ignition driver and the others are the injector drivers.
After we look at some datasheets, we will measure and see if we can locate a fault with the driver for injector #3. If we do, we will replace it with one of the working ones we do not need (i.e. injector driver 5 or 6).
If they measure out good, that indicates the fault lies with the input side. It is beyond our ability to desolder and resolder microprocessors. In that case, we would like you to send us a replacement ecu.
Thanks π
Manuel (landscape architect) and his dad (electrical engineer)
