Matthieu-nl I have a m102 without lambda, in the manual it says to connect grey to ground, black to ecu, and 2 white to heating connector. What is heating connector? The white cables are unclear to me
JHM If you don't have lambda in a car - you don't have heating connector either. Connect one wire to the ground, another - to the fuel pump supply
