Hi JHM, yes i realized i had that wrong and changed both to phased. i have the stock cam sensor connected to dh1. do i need to specify that as vvt1 angle 1 in the digital outputs tab?
how do i set up the oil protection? im not sure what value its asking for. psi, bar? i left it at default setting cause i was unsure.
when i tried starting and looked at the diagnostics tab, i dont seem to get any ignition advance, dwell time, or injector duty.
Thank you for replying.
