Giovih When I try to start the car, if I don't accelerate at 100%, it doesn't start, and starts with a minimum of 600rpm and then stabilizes, I tried to increase the "cold enrichment" but it doesn't change anything or it gets worse
JHM Giovih incorrect ICV position on start causes wrong mixture, just like excessive cold enrichment why did you set enrichment as high as 180?
JHM Giovih first, make sure that ICV valve is working then, revert to the stock settings, and try again
JHM At start, 100% throttle will trigger fulload switch and shut off fuel. If this is the only way to start the engine - then manifold is full of fuel, it should not happen. Record a log of problematic start and warmup
Bobexsus Giovih I also have a similar problem but only on cold starts and just a small amount of throttle gets it to start decent are you on the latest version I noticed the start and idle settings are a little better on version 4.
Bobexsus Giovih Are you using the m102 nav settings as a base I find the the regular settings are a lot better for starts or what I did is keep the nav file and copy the number from the regular m102 calibrations for engine start
JHM You can tune engine start. If engine fires up good, and then RPM is too low - tune "add after start" settings on Idle page. If engine struggle to fire up - tune "Idle position add on cold", on Injection - Start page.
