JHM Yeah it was rubbung with with bare metal right behind the front grille next to the right headlight.
Any idea why the idle rpm sometimes takes like up to10sec to drop from 1200 to 800rpm other times they dont even drop until I shut down and start the engine again, even when letting the car coast in neutral they dont go down but rather stay at 1100-1200rpm.
I did used some carburateur cleaner and wd40 to clean the idle valve when i was installing the injection, before with KJ-tronic never had this issue.
Thank you.
