KielMiller JHM ok, If you need me to test anything please let me know…. Also while testing please check spark output. For some reason the spark output does appear weaker with hall inversion
KielMiller JHM Ok, with the beta software I do NOT need to use Hall Inversion. I was able to set 0 degrees at cranking and get the engine to start and run. Timing advance works properly.
