JHM Audic4driver No, batch injection requires even cylinder number. Try this new FW: https://invent-labs.com/en/jetronic/files/firmware/v4.1
Audic4driver i have do the update, but my car isn’t ideling correctly, i have recorded one log. Can the problem come from the VEZ? Or that the modification in the distributor from the ignition is not prefect in 1,1 mm?log-audi-aar-v418-20261023-184627.csv139kB JHM
Audic4driver @JHM Ok I have tried a new distributor and added the 1,1 mm modification, it’s done very precisely and the car has the same issue. I will test this with the invent ignition control tomorrow .
Audic4driver @JHM the car works fine with the invent ignition control. For the mechanical distributor position, should I set the engine to TDC (0°) and align the rotor with cylinder 1 before calibrating Zero Angle Correction, or should I set the crankshaft to the factory ignition timing mark (15°/18° BTDC) first? I followed the Fixed Angle 0 procedure and calibrated the timing with a strobe light. The idle is now stable, but I want to confirm the correct base distributor position for the AAR.
JHM Audic4driver You should set it to TDC with the "Fixed angle = 0" mode. This is the correct setting for Invent
Audic4driver JHM I followed the ignition calibration procedure described in the Invent instructions. I set the engine to TDC (0°), aligned the distributor rotor with the cylinder 1 reference, selected “Fixed Angle = 0” and checked the timing with a strobe light. The flywheel mark was exactly at 0°, so I didn’t need any Zero Angle Correction.
