Mine is an M116 420SEL, so the manifold layout may differ from your M117.
On mine, a metal pipe runs from the EGR to the lower intake plenum. I cut it near the area marked 68 in the diagram, then connected the remaining pipe to the ICV outlet using ¾-inch PCV hose. I also had to clear the clogged EGR passage. Once that airflow path was established, the engine could idle without stalling.
The factory ICV was another part of the issue. It moved when tested on the bench, but seemed slow to respond while running. Unplugging it after startup gave me a steady, elevated idle, which suggested that the valve’s airflow and control needed more investigation. Our factory valve closes as current increases, so getting the control settings right matters.
After adjusting the Invent settings, mine now holds idle on its own. I still need to tune compensation for A/C and putting the transmission in gear, but the base idle is working.
Converting to the Audi-style ICV could be a quicker solution. Invent calibration would make more sense, as its working as calibrated. If the recommended unit is a stepper valve, that would move away from our factory current-controlled arrangement. The exact valve type and controller compatibility need confirming first.
Your brake-booster-hose test sounds similar to what I experienced: providing another air path allowed it to idle. I’d check the ICV plumbing and repair that damaged connector before taking the manifold apart again.
