I have recently mounted invent, only that I always have the map sensor at 100%, and through the dashboard the map sensor gives me an error, but it is connected to the intake manifold
Two sensors failed at the same time - it's hardly possible.
Check connector - maybe it's not fitted properly.
The intake air temperature sensor is ok not touching anything, checked the connectors and cables, correctly mounted, the car makes a lot of smoke just why the sensor it is always at maximum Sorry for my english.
Record a log of engine start and operation, I'll check.
Now i dont have the pc, but i have apk on android, it does not make me forward the logs, as soon as I solve it I send you the logs
You can share to a filesystem and then attach the file to the forum post.
It can be made by some file managers or apps like this: https://play.google.com/store/apps/details?id=com.boxhead.android.sharetofilesystem
Personally, I'm using Solid Explorer file manager, which is great FM, and also have ability to save shared item to the file.
Thank you, you have been very kind, but it does not let me upload the zip file to the site, I tried uploading it to wetransfer https://we.tl/t-HstH1EVIPK
reading the logs, I see that there is no voltage to the map, how could i solve?
Check 5v at the MAP sensor connector
BTW, I've fixed file upload issue, thanks for reporting it.
The map sensor world only at full throttle, at a idle It detects that a full throttle.
What you see is the limp-home operation mode. It is activated when MAP sensor failed.
Check if MAP sensor has 5v supply. If not - problem with wiring. If yes - MAP sensor is faulty, we can replace it or send you money for buying a new one.
JHM yes, the 5v arrives, when I'm full throttle, the map sensor works and goes to 30/40 ... it works the other way around ... I think it's the map sensor, it's strange .. it's new
Yes, it seems that MAP is faulty. What's your car?
JHM 190E 1991 m102 2.0, tomorrow I'll check again to be sure if it's really the faulty map sensor
i checked and everything is ok, i think it is the map sensor ..
See if you can buy those sensors. We'll pay for it.
JHM thank you very much, are there any differences?
Giovih either will fit
JHM ok good, how can we proceed for the payment? do I contact you privately? if yes where? thanks and sorry for the trouble
Giovih write me to support@invent-labs.com to discuss details
