I tried it today with commander and firmware 4.1.7 update 2 and the stock calibrations from 4.1.7 for Audi 2.0 5 cylinder (in the folder from 4.1.7 ist says 4.1.5 Audi 5 cylinder 2.0, why? ist this a problem?)
Idle was still high i even compared the valve numbers with them in the Commander.
The first log shows how the engine runs when warm with the high rpm.
When i use the manuel slider in the Commander the Valve DOES NOT MOVE!
Then i tried to block of the valve inlet completly while engine is running which you can see on the other log. The idle rpm goes slidly down but engine does not go out.
So ist it a air leak or something wrong wit the valve?
Thanks for helping
