VladimirYesin I noticed that in new commander RPMs are not showing for m103 engine, the old one 4.1.7 show them
JHM 26.9.21.1 New features Bluetooth LE — connect over Bluetooth Low Energy in the 64-bit Windows app; pair the device in Windows Settings and pick it from the port list. Map plot toggle — maps switch between off, 3D, 2D. Ordered table axes — editing an axis value keeps the axis in order by moving the neighbouring values along. Calibration check on connect — when the data read from the device needs correcting, the app asks before writing the corrections back. Fixes Table values — no longer drift by one step and get written back to the device on connect. Bit-field parameters — no longer reset to zero when read from the device. Reset to defaults — no longer wipes the table a linked axis points to. Save with comment — OK and Enter now save the comment. 26.9.17.1 Improvements Switch options — shown as a pair of toggle buttons. Log viewer — channels listed in device parameter order. Reset table to defaults — hidden on tables without defaults. Fixes Table colours — single-row tables are shaded by value again. Jetronic Turbo tables — row labels update immediately. Table marker — no longer drifts on narrow tables. Saving calibrations — no longer fails on leftover text data read from the device. 26.9.7.1 New features Reset table to defaults — a button in the table editor restores a table to its profile default values in one click, with a prompt to handle any axis you've customized. Fixes Closing unsaved calibrations — leaving a calibration with unsaved changes now saves it automatically as "Closed" instead of prompting you. Play button icon — fixed a broken icon on the log view's play button. Calibration page stability — fixed a rare crash ("infinite layout loop") that could occur when opening certain calibration cards. Live readout precision — live value readouts now match the channel's defined decimal precision instead of showing raw, unrounded numbers.
