namron_s Hello guys, I have a question about the AFR table. I use a narrowband probe. Can I still change the values in the table for each engine speed and load conditions or does only AFR14.7 work? Does the VE table adjust automatically? Thank you for your help.
JHM namron_s yes, you can alter AFR table if the value is not 14.7 - the lambda control will be disabled, and the system relies on the table values only, without any feedback
