Viktoras Hello, I have some problems with MAP and Lambda sensors. MAP and Lambda errors appear while driving, after turning off and restarting the car the errors disappear and reappear after a few seconds. Wiring is good. What could it be?
JHM Bad throttle switches cause MAP error and limp mode, and then lambda can't keep the AFR and fails too
Viktoras I will check it and mabye change with another. But as long as I'm connected to the ECU with my phone, there are no errors.
