I was tracing the problem and found that the stock ecu 10a fuse had blown (so the rmp reading is probably fixed). After fixing it i didnt start the car but started testing micro switches. I had wired just like the "Upgrading my VW Mk2 Scirocco 16v to EFI | Invent Jetronic Install" video because i have a golf mk2.
I pressed down the idle microswitch and FullLoad was green, by pressing the WOT switch the Idle turned green. When the throttle is in the middle both are green. Would the "throttle switch inversion" fix this?
