Abezy My car's ecu is kinda damaged, so im not getting grounds on pin 1 and 3 for idle/full load switch, could i just cut original wires and connect jetronic's ecu pins to those pins and will it work fine?
petrolhead Pin 2 is the ground of throttle switch(38). Check that ground. And check the altitude sensor(34) if it's not interrupting the ground. Often people assume the ECU is broken when it's not.
Abezy Hey, thanks for reply, so I can't just use jetronic ECU for those switches? Cuz it's basic k jet car, well was, so those switches should in theory just control idle valve which will be controlled by jetronic ECU
