Winther92 Hi, after about 5 minutes of operation my lambda probe reports an error. It is connected like the instructions. Where could the error be? See attached picture.
JHM It looks like you have a rich mixture and the lambda controller is out of range. You need to adjust the fuel correction.
Winther92 JHM Hi again, now I have adjusted the fuel both at idle and with load. But when it is cold and idling it shows lamda fail after a few minutes
JHM Winther92 Error is detected if either: lambda correction is out of range (that's why you have to adjust the fuel corrections properly) lambda probe signal did not appear in a predefined time window (the sensor heater is malfunctioning)
Winther92 Okay, good to know. But it's while it's at high idle when it's cold that it runs outside the window? When I reset it there are there no problems once it has dropped to normal idle.
JHM Winther92 Lambda starts working from coolant temperature 40 degrees. Record a log of a cold start until it fails.
