I've got the jetronic fitted and it's working great, except for one thing. After driving for a bit the engine idles high (1500 rpm) for a while and then very slowly ramps down to it's set idle value. I've checked for air leaks.
The idle switch it working as it should.
Is there something that would cause this or have I input some incorrect values somewhere?
Thank you
