Hello,
I have installed the Invent Jetronic kit on my M102.961 but I can't get the full load switch to work.
Therefore I have tested the full load switch connection with my multimeter and here's the values I got :
Not Wide-Open-Throttle : 58.5 mV
Wide-Open-Throttle : 58.2 mV
So I guess the switch is doing something, however, I do not know if those values mean anything to the ECU.
On an unrelated note, I also noticed my ECU is configured with the "Bosch 107" injector type setting, yet I'm using Bosch 0 280 158 038 injectors therefore I would like to know if I should change the injector type setting to "Bosch 038".
Thanks in advance for your help.
Best regards.
