Hi,
I'm waiting for my kit to arrive, but since I want to get the system running as soon as possible, is it possible to run ignition control without grinding the distributor?
In other words, simply connect the EMUL wire to the coil amplifier and enable ignition like mentioned here: https://invent-labs.com/en/jetronic/docs/en/installation/ignition_control.html
While I assume this is possible, the documentation does not mention it explicitly.
Thanks!
